going rate to wire up a LS1 combo
wondering whats you guys out there would charge to wire up a LS1/4L60 combo into a 67 Chevy Pickup. i'm gonna be wiring the entire truck from front to back and also wiring the engine.
what would be a good price to charge the guy??
any thoughts.
Sorry for the dumb thread.
any thoughts.
There are way too many factors in that question..
Are you using a new harness, a vehicle specific harness, or just reworking a stocker and starting from scratch?
Is the body on? Or can you run all your frame wiring without the body?
I have 5-6 hours into reworking just my engine harness alone. Granted I'm OCD and cut each wire to length, wrapped in dry vinyl, then PET sleeving. Lol
Depending on the circumstances I would charge $150 on the low end and up to $650 on the high end. Ha ha
an engine harness typically takes me about 10 hours including the time it takes to build a fuse box, solder all connections, tape, heat shrink etc.. I would imagine it would take just as long if not longer to do the rest of the truck.. I charge 200 a harness so 20 bucks an hour.. 25 hours.. 500 seems reasonable if you dont have any snags.
