OE Wheels C5 Deep Dish
18x10.5 C5 Deep Dish with 285/35 tires for rear on 2000 formula
I read in the sticky that this setup will need a spacer or a BFH. I really don't want to use the BFH. It has a 56mm offset. What size spacer should I get and where is the best place to get them? And will the spacer work with the stock studs/lugs? I also plan on lowering it 1.25".
if its stock riding height then you should be fine. ALL CARS ARE DIFFERENT. I have the same wheel with a 295/35/18 and had too use the BFH a little since im am lowered 1.25inches as well, some other guys didnt have too. ALL CARS ARE DIFFERENT. You may need a spacer but there is only one way to find out.
Why dont you want to use a BFH for?
That's also $200 more than the polished. Plus I like the staggered look. Really.. No one is running c5 brakes with these wheels? I must have had a unique idea or something.
