2001 Pewter B4C RPM built trans stalled Bolt-ons Updated pics
Year: 2001
Make: Chevrolet
Model: Camaro
Price: $6800
Mileage: 170000
Private or Dealer Listing: Private Listing
Location (State): IN
Color: Gray
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Up for sale is a 2001 B4C that we just got finished with a few months ago. The car is 1 of 31 built that year in regards to color and trans. It is an ex Indiana State Police car, I removed all the wiring I found they left over. Car has 170k on the dash.
Exterior/Interior is 7-8/10, nothing major, just minor wear and tear for its age and one paint defect on right rear fender where a dent was repaired. We swapped the doors, front fenders, hood, and nose from an 02 pewter B4C as the originals had some clear coming off. Driver door still needs a lil adjustment, Im gonna try to get to. All the paint on the car is original GM paint. Light wear on driver seat bolster, and top of steering wheel.
Engine mileage is somewhat unknown, it came out of a 200k mile 02 B4C, but the way it runs and has great oil pressure led us to believe that there is no way it was original with 200k. Has a new water pump, alternator and starter from a 140k mile car, AC is cold, new belts. New seal on oil pan, rear cover, and rear main. Engine swap was done from the bottom and done right, youd be hard pressed to tell it has ever been out. Brakes have some meat left, tires are decent. Car runs great and really only needs struts, I was planning to grab some lower mileage stock decarbons on here or buy bilsteins. Mod list below. You can also text me at 7six5-3four1-11seven1.
Performance:
SLP Lid
SLP smooth bellow
ASP underdrive pulley
Poly Motor Mounts
1 7/8 ARH headers and catted y(cats gutted, and bung welded and plugged for wideband)
Mufflex clone catback with Magnaflow 4x9 in stock location
The car was also tuned locally.
Mike Norris Catch Can
All trans work done by RPM and I believe is still under their 90 day warranty(gotta check date), if there were any problems I believe Jeremy and the crew would work with you to sort it out, but Ill have to confirm that with them at a later date. The trans and stall really changed the car, great setup! Have receipt as well.
RPM lvl 4 4L60E(less than 5k miles)
Vig3600(less than 5k miles, awesome drivability with the lockup and 20mpg average)
TCI flexplate(less than 5k miles)
B&M cooler(less than 5k miles)
Appearance:
Black Leather Seats F&R in good shape lil wear on drive bolster
Black Leather door panels
Depo Whistler Headlights
SLP SS grille painted flat black and red bowtie emblem
Stock 5 star wheels painted black with polished lip
I picked up and built this car with the intention of keeping it for a long time and continuing to build it up over time, however I am now trying to buy a house so toys are playing second fiddle. This would be a great starting point for someone to pick up where I left off. I am going to list it for 7k that is including some money for parts, since I know what I can get for the car and all the parts separate I can’t go much lower but some wiggle room. If there is no interest it will be returned to stock inside and out and sold that way over the winter. You can not buy another fbody and replicate the setup for the price its listed. Title and clean Carfax in hand.
Any stock parts I have go with the car, including the stock cloth door panels. A deal for cloth seats could be worked out with a friend of mine if someone wanted the car to be more original.
Yeah only once right after stall was done, was in the summer heat wave we had on these old street tires. I couldnt launch the car for anything, but best of the day out of 3-4 passes was 13.0x at 106-107 if I remember right. Sucking all hot air from the bay too, I havent even done the free ram air mod and bone stock suspension. Car should be mid low 12s with drag radials. Plan was to have a bolt on stall suspension car that went 11.9x
Used to be my car, helped with the engine swap, and drove it after the stall. This man does not cut corners on anything and is very honest. Someone buy it before I buy it back.
