weight difference between a stock 92 z28 and a stock 2000 z28
Old 10-23-2012, 07:04 PM
bungy74's Avatar
Default weight difference between a stock 92 z28 and a stock 2000 z28
anyone know the weight difference ? I was told the 3rd gen is lighter
Old 10-24-2012, 10:37 AM
bczee's Avatar
From what I recall and have read..
Shipping / Curb weight of a 3rd Gen is about 3200 lbs and the 4th Gen is about 3400 lbs.. about 100 lbs more.. from that point you can start adding the optional weights..
I think generally you will see weight of the 3rd gen from 3300 to 3600 lbs and the 4th gen 3400-3800 lbs when optioned out and delievered.
I recall my friends 84 Z28 when we ordered it for SCCA F Stock, which was pretty much stripped of ordering any options.. weighted in around or just under 3300 lbs.. and my 84 which was optioned out was around 3500+/- lbs.
Here is a good artical to uses...:
http://www.f-body.org/tech/tech.htm#weight3rd
BC
Quick Reply: weight difference between a stock 92 z28 and a stock 2000 z28
