LS1 f body waterpump,alt,p/s pump and brackets
I need a f-body LS1 waterpump, alternator, p/s pump, balancer, a/c compressor, pcm, brackets, hardware, tensioner and idler. Basically all the front end accessories to put f-body accessories on a truck engine for a swap that I'm doing. Thanks.
I have the complete front accessorie drive set up from a 2002 WS6 with 66k miles on it with every nut and bolt.
LS1 Water Pump with Bolts
Alternator with Bolts and brackets
PS Pump with Brackets. will need new pulley and reservoir.
Balancer
Tensioner
AC Bracket
Ac Compressor but sensor plug is cracked.
LS1 Auto PCM tuned for MS3 cam
$400 plus S/H
