Will this Cam work?
Will this Cam work?
Rebuilding an LT1, freshing up bottem end with aluminum heads. I have a complete comp cam kit laying around. It's the Thumper series, Duration is 295/313 and the lift is 500/486. Will this work with stock bottom end and rebuilt trans with stock converter? May be a stupid question for some, but not to me.....
Thanks ahead of time for all the input....
You will need to have the nose of the cam drilled (if you are using it with a vented opti) otherwise it won't work. Also the cam needs to be step-nosed (for 87+ roller blocks). I suggest getting an LT1-specific cam, not that monstrosity.
And ideally those duration/lift numbers are awful for a "freshened up bottom end" with stock heads and a stock converter.
