Notices
Vehicle Classifieds This an archive of the older vehicle classifieds, please create a new listing in our Marketplace.
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
68 chevelle / lsx / procharged / back halved
Old 10-25-2012, 09:30 PM
night ryder's Avatar
Default 68 chevelle / lsx / procharged / back halved
Year: 1968
Make: Chevrolet
Model: Chevelle
Price: $29999
Mileage: 0
Private or Dealer Listing: Private Listing
Location (State): SD
Color: Black
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
1968 Chevelle with clean title. wanted to go for the fastest stock 5.3l car, but changed my mind and want to get back into a small tire car. here is the list of things done to it. car made 606whp on 16lbs. currently on 23lbs. car is currently painted with some cheap PPG satin black. the car needs to be sanded down and repainted.
Car:
2870lb without driver
10+pt chromoly roll cage
15x17 Weld Racing rear with 33x14.5 slick (comes with extra set)
15x3 Weld Racing front with mickey thompsons
Vfn lift off front end (headlight still work)
Vfn 4" cowl front end
fire wall has been cut, and the motor has been moved back 8"
ARC 2000 switch panel
aluminum dash
all autometer gauges (trans temp, water temp, boost, oil, wideband, 5" tach)
precision shifter
kirkey seat and cover
belts are brand new
removable steering wheel
wilwood front disc brakes
aeroquip rear disc brakes
dual wilwood master cylinder
Motor:
5.3L motor
front / mid motor plates with travel limiters (urethane trans mount)
ls9 head gaskets
ARP head bolts
Brute speed supercharger cam
.650 valve sprigs
chromoly pushrods
ls1 intake / fuel rails
ls1 oil pan
bosch 210lb injectors
ebay valve covers
35gpm meziere water pump
Summit brand Radiator / Fan setup
Stainless braided water lines
Stock ls1 computer
Truck coils
Firecore spark plug wires
high flow oil pump
double roller timing chain
QTP stainless headers
Procharger:
F1A COG setup with 13 passes
Tial Bov (used as bypass)
Precision 39mm wastegate (used as boost controller)
HBC Manual boost controller
ATI balancer
Fuel:
e98
Holley dominator pump
stainless feed and return
aeromotive fuel regulator
10 gallon plastic fuel cell
Suspension:
Dana 60
35 spline axles
spool
3.54 gears
Back Halved
4 link
Strange adjustable coil over in rear
Qa1 coil over in front
new urethane bushings in front
front ebay upper control arm
transmission:
th400 with ati rebuild kit
ati reverse trans brake
deep oil pan
TCI flex plate
CSR flex plate shield
ultimate converter (good for 1500+hp)
im probably forgetting some stuff, but you can get the hint that the is well built. car has been 9.55 at 143mph with a 1.50 60ft. the converter needs to be sent in and re stalled as it will only go to 3400rpm on transbrake. can send many more pictures upon request
Old 10-28-2012, 11:55 AM
pwrtrip75's Avatar
What is your bottom dollar for us down here on earth?
Quick Reply: 68 chevelle / lsx / procharged / back halved
