Notices
Vehicle Classifieds This an archive of the older vehicle classifieds, please create a new listing in our Marketplace.
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
2000 mmm z/28
Old 10-27-2012, 11:50 PM
Double_Trouble99's Avatar
Default 2000 mmm z/28
Year: 2000
Make: Chevrolet
Model: Camaro
Price: $7900
Mileage: 84247
Private or Dealer Listing: Private Listing
Location (State): IA
Color: Red
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
time for me to put my camaro up for sale as im wanting to do another project. i bought this car 13 months ago bone stock from an older gentlemen who took very good care of the car. never had any problems from this car and have really enjoyed it and have took it on many long road trips to various lsx based events around the usa.
i have very good maintenance records for the car and dam neer all the receipts for the parts that i have put on the car except parts i have bought used but actually have paypal receipts for a few.
*******$7900 obo********
motor..cam install has around 600 miles on it now
SLP lid
k/n filter
stock maf w/screen
ported T/B
ported ls6 intake
pac 1218 springs
correct length trick flow 7.4 pr's
comp reverse split cam
specs:XER/LXL 224/221 581/566 113+2
ls6 valley cover
100% custom built catch can
ls2 chain
160 stat
rebuilt oil pump
new gm o ring for pick up tube
pretty much all new gaskets through out except for rear cover,new timing cover seal
b&m 29.1 sfi flexplate
stainless alen bolts throught out engine. remaining bolts were polished
poly motor mounts
black msd wires
fresh tr55s @ 50
ARP crank bolt
exhaust
high temp flat black coated pacesetters
TSP y pipe with modded with a true 3in Y into a magnaflow i pipe then into a custom built TOTL style axle back that has 3in. outlets. muffler is a heavily modified flowmaster 40 series with baffles removed and re welded internally
best sounding set up ive had on a f body before. no rasp and can have a conversation while driving down the road and sound mean when on it.
trans....trans and converter has around 600 miles aswell
maxwell transmission built w/ all the goodies 4l60e
vig 4000
all number 6an line and fittings "fragola" and big cooler with dei heat sleeving around lines till front of motor for safety. secured with rubber isolated clamps were needed.
poly trans mount.
ive had many trans built by maxwell transmission and always have been very confident with there skill level and costumer service is by far best ive ever dealt with not to mention his warranty. initial build was $2700.
suspension
MWC SFC's
BMR poly/poly hammertone lca's
founders relo brackets
edlebrock poly on car adjustable PHR
SA QA1 coil overs in front W/275lb springs w/bearing plates
rear are brand new bilstiene (sp) shocks as i had a rear QA1 leaking...will come will sale of car. car send them out to get rebuilt. only one is leaking.
all suspension bolts that were removed for install of these items were replaced with coated grade 8 bolts.
appearance
nothing special lol wanted to stay a little low key
tinted lights
18 zr1s in very good shape but tires arent the best. car normally has stock snowflake wheels in gun metal with good front goodyears and great set of 255 mickeys on back
painted billet grill
gloss black berger panel.
interior
stock and in great shape with very minor wear on drivers seat no holes or anything.
accessories
PLX M300 wideband mounted for drivers convenience w/new o2
SLP fan switch mounted under cig lighter
rear end
stock 3.23 gear with fresh fluid
perfect launch girdle
wines a touch
brakes...27xx miles
brakemotive slotted rotors and pads. great shape still
maintenance
oil is changed every 2500 miles
trans fluid has been changed 3 times now since being freshened up with 2 new filters to make sure all assembly lube and any shavings were not in trans.
fuel filter has been changed twice in the last year
new denso o2's were put in aswell during the cam and trans install.
***car is on a old base tune and needs to be tuned. we put fuel in it for wot to be safe but left timing alone. alot left in this combo for sure. with that being said the car has gone a best of 12.32 @109 with a 1.62 short time. while pulling the tire... car is very consistent the way its set up right now with sixtys ranging from 1.62-1.64 et's are 12.33-36. have all slips with notes on them... car weighs 3595 w/ 330lb driver. obviously with a good tune and lighter driver car will be in the 11s i have all parts that were removed and can go with the new owner if you want. .****
car was very budget built to be a great street car and turn a few 11 sec passes at the track and to be enjoyed.
bads. has a couple small scratches in the paint and a ding on the hood.
clear coat is peeling a bit on front bumper from a few rock chips and when i was quickly washing it before work one day at the car wash i got the wond to close and water got under the clear. over all the car is a driver and not a show car but cleans up very nice. if bumper was redone the car would look great.
im sure im forgetting things and if you have any questions or concerns please do not hesitate to call,text or pm me. 563-650-5375 jim.
heres some pics ive taken in the last few weeks.
Old 10-27-2012, 11:54 PM
Old 10-27-2012, 11:56 PM
Old 10-28-2012, 12:17 AM
some older pics of the sfc's
Old 10-28-2012, 12:22 AM
older vid when was 3200 converter. can here the exhaust fairly well.
edit. cant seem to get vid to work...
Old 10-29-2012, 10:26 PM
Up top.
Old 11-01-2012, 11:08 PM
Up top..
Old 11-04-2012, 12:55 AM
Up top..
Old 11-04-2012, 01:09 AM
LT1TransAm's Avatar
Interested in any trades?
Old 11-04-2012, 10:08 AM
Not at the moment, Unless its a g body el camino.
Old 11-06-2012, 08:35 AM
Bump it
Old 11-08-2012, 11:10 PM
Up top
Old 11-10-2012, 03:15 PM
Obo guys. Need to move this car
Old 11-10-2012, 08:49 PM
NoRotor88's Avatar
This is a VERY clean car folks. Jimi takes care of his stuff and is very particular about his cars and the modifications he does to them. Someone will be getting a reliable, clean, consistent car.
Good luck, Jimi!
Jesse
Old 11-11-2012, 05:12 PM
Thanks jesse!
Old 11-12-2012, 09:29 PM
Bump it
Old 11-13-2012, 09:03 PM
mod
mod's Avatar
bump for a very nice car wish I had some more room and money
Old 11-13-2012, 09:23 PM
Thanks!
Old 11-14-2012, 06:20 PM
up top
Old 11-15-2012, 06:40 PM
Open to offers need this gone..
Quick Reply: 2000 mmm z/28
