Car turns off while running please help!
1st off the cars a 93 lt1 a4
A few months ago the car went down and i replaced the fuel pump,fuel filter,opti,icm,coil,wires,plugs.And the cars been running good til a couple weeks ago.
Now the car while running just turns off either at low speeds,high,or idle.Doesnt really make a noise just shuts off. sometimes it starts right back up and then sometimes it takes awhile.
I thought it might be the icm so i replaced it with warranty. then i replaced the fuel regulator and nothing.
Any info will be much appreciated!!
I have a 94 trans am that would shut off around 180 degrees every time and would sometimes start up after awhile but sometimes not. Sometimes it would not start even if cold, it ended up being the opti even though it was changed 6 months prior. We thought icm as well but unfortunately no dice so maybe look into the opti.
