LS1 Moser 9" & MWC Fab 9"
Category: Racing Parts
Price: $1850
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): NE
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Moser 9", Aluminum Pinion Support, Detroit Truetrac, 3.90 gears, LS1 brake backing plates, 3 channel ABS, 1350 forged yoke, Nodular Case, 31 Spline Axles, Fill AND Drain plugs, - $1850 plus shipping
MWC 9" with Chromoly Torque Arm, long arm with LT1 6spd trans mount. If using with an LS1 or A4 LT1 you would need to contact MWC and have a transmission mount specifically made for your application. Strange Center section with Strange "S" Nodular Case, Detroit TrueTrac, 3.70 Yukon Gears, 3 channel abs, Black Powder Coated, 31 Spline. $3615 new as optioned (+ brake calipers,rotors,lines, cables etc). ONLY 1500 miles on it, $2950 shipped via frieght to a business or freight terminal near you.
This rear can be converted to use with LS1s if you want to swap the brake caliper brackets. Or you can use the provided LT1 brake setups and directly swap in the rearend into your LS1. (there is no performance difference/advantage between LT & LS rear brakes).
Local pickup is welcomed. $119 to ship it to you via business with forklift/dock or terminal near you. add $100 for residential if need be.
Price on the Moser 9" is 1850 PLUS shipping for those who have asked. Had a few requests for shipping costs and have responded to your pms on those.
