Computer issues
LS1Tech Sponsor
In the glove box, above the glove box?
Jon
PSI
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
LS1Tech Sponsor
We use a grommet seal on our harnesses.
Jon
PSI
Jon
PSI
__________________
Ebay Store
Ebay Store
If you are going to install a Vintage Air a/c I would highly suggest you install the evaporator now and then decide if you can fit your ecm under the dash. I have the smaller E38 ecm and the glove box was the only place that you could reasonably fit the ecm, so I mounted mine under the hood on the radiator support, https://ls1tech.com/forums/16355047-post160.html
