wiring harness question
im doing a ls1 swap on a 93 rx7.. the ls1 with harness and ecu came out of a automatic transmission and im going to use a t56. do i have to get a different harness being im not going back with a automatic?
+1..... Especially for the reverse lockout. Ive heard alot of stories about speed shifting and ending up in reverse thereby scattering a very expensive trans all over the road. Just my 2 cents...
LS1Tech Premium Sponsor
It is possible to convert your harness to a manual harness, there is some information in the Manual Transmission stickies. It can be done though.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
LS1Tech Sponsor
You can repin one of your transmission wires to the correct location at the PCM for the reverse lockout. Then use the power wire for the automatic transmission to power the reverse lockout. Change the tune and you should be good. Hope that helps.
JON
PSI
JON
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
This is exactly what I did when I re-pinned/swapped the trans on my 98 car. Sounded tough at the time, but took maybe half an hour, and most of that time was getting the car on the lift and splicing in a pigtail.
__________________
Should be the same concept.
__________________
You can add the wires and use the computer lock out reverse at low speeds, or you could just wire the lockout to only allow reverse when brakes are on using brake switch.
