What starter do I use?
Old 10-28-2012, 08:12 PM
Powe's Avatar
Default What starter do I use?
As the title says, which starter to us on my 67 nova? LY6 block using t56 from 2006 GTO? I purchased a tick performance clutch kit which comes with monster 2 clutch and flywheel, slave, mc, etc...
Old 10-28-2012, 08:14 PM
85MikeTPI's Avatar
Are you using a GTO T56 bellhousing also?
Old 10-28-2012, 08:54 PM
Powe's Avatar
Not sure if it was the exact oem one but it's not aftermarket... I bought it used with t56.
Old 10-28-2012, 09:04 PM
Powe's Avatar
Old 10-28-2012, 10:05 PM
lizeec's Avatar
The starter for a GTO bell housing is just a little bit smaller than a F body starter, the GTO starter WILL work on a Fbody T56 bell housing. The Fbody starter WILL NOT fit in a GTO T56 bell housing, although I have read some threads where people have ground out the GTO T56 bell housing to make the Fbody starter work.
Old 10-28-2012, 10:31 PM
Powe's Avatar
So no matter what I'm safe with a GTO starter? Even if the flywheel is not GTO or are all manual flywheels the same?
Old 10-28-2012, 11:03 PM
garys 68's Avatar
Do a search, seems GTO flywheels, sterters, bellhousings are not the same as vette, f body, or truck.
Old 10-29-2012, 10:00 AM
Powe's Avatar
Just found out that I bought a f body fly wheel.. He said if its a GTO bell housing then use GTO starter bc that's really the only difference is the starter pocket.
Old 10-29-2012, 10:39 AM
lizeec's Avatar
2004 GTO and 1998-2002 flywheel is a LS1 style
2005-2006 GTO is a LS2 style
Flywheels will not interchange from LS1 to LS2 the pressure plates are also different, I am not sure if the actual clutch disc is different.
Quick Reply: What starter do I use?
