crank position sensor?
car would startup,
drive normal,
would randomly buck at constant highway rpm.. shuts off cruising sometimes
rpms drop 3-400 rpm while cruising
shuts off when coming to a stop.. feels like it is starving for fuel..
fuel pump died.. replaced with aeromotive 340
idles perfect, starts up perfect
drives normal for a few miles.. then same symptoms.. CPS code appears.. disappears.. reappears.. disappears.. only come son when car bucks violently, no misfire codes
decided to park it and change the CPS sensor today and see what happens
is that a symptom for anything else other than the cps? Im changing the fuel filter, putting in new fuel, already sea foamed, changing plugs with br7ef (nano install) changing CPS,
anything else i should check or am i good to go? thx
drive normal,
car would startup,
drive normal,
drive normal,
Umm, if you are getting a CPS code and it is running bad like that then YES...more than likely your CPS is bad. Consider yourself lucky it threw a code at least
