Will ls1 fit 3.8l 5 speed?
Old 10-31-2012, 10:03 PM
dkiller2135's Avatar
Default Will ls1 fit 3.8l 5 speed?
I got the ls1 out from a lq9 with 243 head swap. I'm looking in to what's reasonable to use the old engine for. Seen a cheep 98 fire bird 3.8 5 speed needing a motor and just wonder if its worth the trouble.
Old 11-01-2012, 02:18 AM
bww3588's Avatar
Not without an expensive adapter bell. The 3.8 bell is the metric pattern, and the trans is different from the t5's in the older Camaros with the regular Chevy pattern. Not worth the trouble. Pony up to a t56 or find a decent 4l60e from an ls1 and run it.
Old 11-01-2012, 08:33 AM
mark21742's Avatar
Build a rat rod, that's what I'm doing with all my parts I have laying around the garage
Old 11-01-2012, 01:11 PM
wildcamaro's Avatar
Yea sell the 5 speed bc if you could adapt it it wouldn't last very long behind and ls1....get a 4l60e or a turbo 350 if trying to do it cheap. Turbo350 only needs a 20 dollar adapter to make it work. Good luck man
Old 11-01-2012, 02:48 PM
garys 68's Avatar
The BOP bell housing wont fit.
The trans/bell bolt pattern is ford.
The input shaft is an odd spline count.
The 1st gears are usually 3 something and are only rated for under 300 ft/lbs.
Not worth the effort.
Old 11-01-2012, 08:48 PM
Good advice men. The rat rod does have sound apeal.
Old 11-02-2012, 09:06 AM
mark21742's Avatar
Here is mine I'm building with spare parts laying around
Old 11-02-2012, 09:11 AM
mark21742's Avatar
Old 11-03-2012, 04:22 AM
CAL99SS's Avatar
That's damn cool man. ^
Quick Reply: Will ls1 fit 3.8l 5 speed?
