Need **PICS** of MWC SFC installation points
Weak sauce, I know. But after fiddling with them for a bit thinking I can tell my welder where and how, I admit I'm a bit confused. There seems to be no "locating" point. On the driver's side it looks like my brake / fuel lines will interfere in the front. When I get these welded I want to make sure it's done right the first time.
I distantly remember Eric telling a guy after they were installed he missed a few weld spots (can't find the damned thread)
I will say though, these things are RIDICULOUSLY stout!
Thanks for any help guys!
That's the thread I was thinking of.... No wonder I couldn't find it. I kept searching MWC SFC...
My only question:
Is this gap ok? After trying to "dry fit" mine I noticed they did the same thing. I thought they would fit flush but they didn't
See the gap I'm talking about?
My only question:
My only question:
My only question:
Just looked into this SFC, interesting piece. Their placement seems to make sense, I think I may be getting one from MWC instead. I wonder why no one else thought to make them that way. Why does it say off road use only, though?
I would just add a small piece of 3/16 plate in the empty spot if it bothers you. Quick and simple solution. Won't take the welder 5 secs to seal it up either.
LS1Tech Premium Sponsor
The "gap" or "empty spot" being referred to in the pics is the end of the factory front subframe. The bracket we have attached to the front of the connector has over 12" of weld surface and the small open space left at this point will make no difference in the performance of the component. If it would make someone feel better that it gets closed up then it won't hurt either.
