what gears to go with...
Old 11-03-2012, 01:02 AM
transam2001's Avatar
Default what gears to go with...
i have a 2001 ws6 auto with 2.73 gears i believe. it has 100k on it and the rear is noisy im gonna ordered a rebuild kit off of ws6 store. why its apart is there anything else i should do... also what rpm would i be at 50-60 and mpg would i get with 3.73
Old 11-03-2012, 10:15 AM
96lt1m6's Avatar
Considering there is not much to gain with swapping gears on an Ls1 car I would not bother with the added RPM at cruise... Don't get me wrong i am all about adding gear but Ls A4 cars don't seem to need gear....Do you have a stall in your car? Do you have and aftermarket cam?
Old 11-03-2012, 12:44 PM
skopers3's Avatar
2.73 to 3.73 you'll notice a difference.
Old 11-03-2012, 08:48 PM
LS1T56FTW's Avatar
From what I remember, the car "feels" a lot faster when doing this swap, but the track times just weren't there. Someone did that exact swap and only lost a tenth or two in their quarter mile time. Then some other dude with the 2.73 rear put a 3600 or 3800 stall in his car and dropped like a second in his 1/4 time.
Old 11-03-2012, 09:54 PM
murphinator's Avatar
Stall > gears
Old 11-03-2012, 10:30 PM
therabidweasel's Avatar
I like my 3.70s. I believe your RPMs will be <2k at 60. Definitely use a solid pinion spacer instead of a crush sleeve. You will probably need to buy a new pinion seal as your kit will include an older version that is too small. I always recommend buying actual gear paint separately because my kit came with grease as a substitute.
Old 11-03-2012, 10:49 PM
ULTIMATEORANGESS's Avatar
Smile
4.10s. they work well for me.
Quick Reply: what gears to go with...
