General LSX Automobile Discussion Non-technical LSX related topics.
Power potential of N/A 16:1 LQ4 on E85?
Old 11-04-2012, 01:01 PM
THEhomelessONE's Avatar
Default Power potential of N/A 16:1 LQ4 on E85?
Around 16:1 compression, have e85 readily available near me. Was thinking of a quick Denali build 4wd launches look darn fun. Seems like it'd cost much more building a 6.6 dmax, plus I'd have more use for an SUV than a truck. If it's not worth the trouble of staying NA, hopefully a 4.0-4.5 whipple with 10.5-11:1 compression will help me hit over 1000whp, man can dream can't he? Thanks for the help!
THEhomelessONE is offline
Old 11-04-2012, 09:20 PM
gt35built's Avatar
Are you trolling? 16:1 compression lsx? 1000hp denali?
gt35built is offline
Old 11-05-2012, 11:56 AM
Gordon0652's Avatar
@THEhomelessONE, do some research.
Gordon0652 is offline
Old 11-06-2012, 07:10 PM
Dmax/04V's Avatar
16.5:1 compression on a solid iron duramax diesel block stock, you can run 60 psi boost no problem....16.5:1 on an LS Block call some eod techs, they can achieve the same result with some C4. I'd love to see a video of this...
Dmax/04V is offline
Old 11-19-2012, 02:50 AM
No I'm serious. Built LQ4 with 16.1:1 compression, all motor. What kind of power would it make? Debating on a full size SUV like a Tahoe/Suburban, or an E36 bimmer. Leaning more towards the bimmer for all motor. Found a few people running up to 16.5:1 and around 11:1-13:1 on boosted setups. A built 4.8 high rpm screamer would be cool too.
http://classracer.com/classforum/showthread.php?t=43683
http://www.yellowbullet.com/forum/sh...85+compression
Old 11-19-2012, 03:32 AM
bww3588's Avatar
Why must you have 16:1 ?
bww3588 is offline
Old 11-19-2012, 07:20 PM
murphinator's Avatar
16 to 1 sounds more like e98 territory especially if you ever get ahold of some winter blend e85 which is only 70% E and only 105 octane thats why they rate e85 at 105 octane - lowest octane you should ever get out of an e85 pump.
murphinator is offline
Quick Reply: Power potential of N/A 16:1 LQ4 on E85?
