Grinding noise while trying to start up
Old 11-04-2012, 08:56 PM
txh0tb0i972's Avatar
Default Grinding noise while trying to start up
I go to crank it and its a big GRINDDDDD!!!!! at first it turned the motor over but didnt turn on.... now its just grinding.... I have switched 3 starters already so its not the strarter... the flywheel looks good from what i can see... what can be causing it to grind? I just pulled the trans out and everything looks good.....
Any help is greatly appreciated
Old 11-04-2012, 09:10 PM
5w20's Avatar
Have you tried spinning it over manually by hand?
Old 11-04-2012, 09:11 PM
its a M6..... I have not tried manually but it did spin freely before the attempt to start it....
Old 11-04-2012, 09:16 PM
5w20's Avatar
Have you removed the pressure plate and disc to physically look at the flywheel? Center section could be broken.
Old 11-04-2012, 09:28 PM
just went outside and rotated engine 360 degrees .... i have not take it completely off but will do tomorrow.... i could not find my swivel to remove top bolts
Old 11-04-2012, 09:31 PM
5w20's Avatar
If you have rubber mounts, you could a small piece of a 2x4 and shoove it between the engine and the body to move it over and give you more room to get to the bolts.
Old 11-05-2012, 01:13 AM
NemeSS's Avatar
Tiene un billete atorado!
Old 11-05-2012, 10:20 AM
Old 11-06-2012, 10:42 AM
pulled bellhousing and clutch off.... Looks like the clutch was not installed correctly .... cause the trans was a B**** to seperate from the bellhousing..... and the "new Pilot Bearing" is trashed..... Im assuming my helper was not aware how to install a clutch.....But took the starter to Vato Zone and exchanged it for a new one... time for attempt 2
Old 11-06-2012, 11:06 AM
DopeFedZ's Avatar
Never work on an empty stomach. Eat some taquitos...
Old 11-06-2012, 11:17 AM
Paisanita Tacos FTW!
Old 11-13-2012, 11:11 PM
1_MEANZ28's Avatar
ke fue siempre?
Old 11-14-2012, 04:48 AM
GMCHammer's Avatar
You need to meet some new mechanics.
Old 11-14-2012, 03:02 PM
SSHAWK's Avatar
You get your car running yet?
Old 11-14-2012, 04:00 PM
no i just left it alone... i dont have time for it.
Old 11-18-2012, 03:00 PM
Problem fixxed!!!!! The little wire (I believe the ignition wire) was hanging on a couple of wires.. clipped off the little terminal deal, put a new one on and fired right up!!!!
Old 11-18-2012, 05:15 PM
5w20's Avatar
Starter wire? Was the starter was staying engaged?
Old 11-18-2012, 06:55 PM
stylezunknown's Avatar
grats bro
Old 11-18-2012, 07:28 PM
Reject's Avatar
wait i thought you sold this car already!
Old 11-18-2012, 08:41 PM
It was that small purple wire.... I just fixed the connecter
Quick Reply: Grinding noise while trying to start up
