Ideals for a 6.2 build
Old 11-05-2012, 08:33 AM
acechevy's Avatar
Default Ideals for a 6.2 build
I got a 1998 z28 wanting to put a stroker motor in. I picked up a 2008 6.2 out of a suv. Thinking about the 427 stroker was wondering if anyone had input or any advice on what products or cam etc. Thanks ahead of time.
Old 11-05-2012, 08:55 AM
87silverbullet's Avatar
A 427 would make a 4.100 stroke crank have to be in there and if you are going to be on motor only that will be fine. If you have a power adder it is not recommended to have that much stroke and to keep it at 4.000. Get with Geoff@EPS or PatG on here and let them spec you a cam. It makes no sense to get something off the shelf when a custom grind doesn't even costs much more. You can take the stock L92's and send them out to be ported and change the springs and valves. Most guys opt for the hollow valves out of the LS3 for their weight and use spring to match their cam. Geoff or PatG can guide you on that. Texas Speed can provide you with all you need to convert the motor over to use the LS1 pcm. To save money also, you can go with an LS3 or L76 intake and have it ported or if you have the money opt for a FAST.
Old 11-05-2012, 10:22 AM
litle88's Avatar
You can also call CompCams and ask for Gab Gray he can spec you out a cam for free, SDPC and racetronix also have your wiring solutions that you'll need. Remember if you stroke it you'll need a 24x reluctor on your crank and keep your old knock sensors cause you'll be needing them too.
Old 11-05-2012, 10:45 AM
acechevy's Avatar
Ok i been trying to find a swap that someone has done far as wiring and knock sensors and etc but havent seen anything only thing i might do is spray the motor every now and again but mainly just motor most likely
Old 11-06-2012, 11:26 PM
ez2cdave's Avatar
Originally Posted by litle88
You can also call CompCams and ask for Gab Gray he can spec you out a cam for free.
Is he actually designing a "full-on, custom cam" or just picking an "off the shelf item ?
Old 11-07-2012, 03:15 PM
litle88's Avatar
It's CompCams bud, if he requests or needs a custom spec cam that's what he'll get.
Old 11-14-2012, 09:18 AM
acechevy's Avatar
Someone said that the 98 ls1 car has different fuel system trying to figure out all what i got to change
Old 11-14-2012, 09:33 AM
Tainted's Avatar
it has to do with the fuel return
Old 11-15-2012, 05:12 PM
cabel1's Avatar
I'm doing this swap now. No fuel issues that I can see
Old 11-19-2012, 08:35 PM
acechevy's Avatar
Ok if u run into any issues let me know lol
Quick Reply: Ideals for a 6.2 build
