whats going out on my tranny?
normal driving:
1-2 is a bit late and when it shifts, it does so with almost a slingshot effect
2-3 the rpms rise between gears...so it starts to shift, rpms rise before it gets to the next gear. like it slips before it goes into 3rd
3-4 is normal
during WOT shifts are crisp and on time at all changes.
3-4 is normal
Originally Posted by samz28
are we talking about the lockup clutch on the ssf3500? or unlocked?
tell you have have 500 passes and 50K miles on that ssf3500
Originally Posted by JustAnotherSS
the car is bone stock, the tranny is a fairly fresh stock rebuild
BTW...the first tranny had the same symptoms as this current one when the dealer replaced it. It was falling flat on it's face between shifts. The dealer said something about there being a flaw in the case design of the 01 and 02 4l60e's that didn't allow enough fluid pressure to build....of course if they replaced the tranny that should have been solved...don't know if that problem actually exists or if it was a load of bs from the dealer.
Good luck getting the problems resolved.
