how to replace the oil pan without leaks?
Old 11-05-2012, 03:36 PM
knaffie's Avatar
Default how to replace the oil pan without leaks?
I was planning on doing only there rear engine cover. I have the rear cover / rear main seal assembly and know how to use the included disc to line it up. But now I need to replace the oil pan too. How do I go about aligning it? Any special hints / tips / advice? Thanks!
EDIT: This is in a custom tube frame, so access is not a problem.
Quick Reply: how to replace the oil pan without leaks?
