T43 OS swap (6L80E TCM)
Old 11-05-2012, 03:58 PM
Cutlass Convert's Avatar
Default T43 OS swap (6L80E TCM)
I am swapping a 5.3 and 6L80E into a 1968 Olds Cutlass. I am piecing together a combination of parts and have been able to read info off the PCM and TCM. My motor is 2011 my PCM is 2011 (OS=12639835) my TCM appears to be 09 (OS = 24249179). I am thinking the easiest way to get things to play together nicely is to change the TCM to a 2011 OS.
My question is can HPTuners do this, and will the TCM hardware support the newer OS?
I posted this on HPTuners forum with no response, so I am trying here.
Thanks,
Pat
Old 11-06-2012, 08:03 AM
71403's Avatar
There are posts about keeping the year of the OS and ECM the same to avoid problems, not sure if that applies to the TCM also.
Quick Reply: T43 OS swap (6L80E TCM)
