450+ hp LQ4 Build on a budget
I know this has been covered before and I know this is probably getting old. But I'm new to the engine building world. I've never built any type from SBC to LS. I'm learning so before anyone says it I have used search and have read countless thread to the point my head now hurts.
My goals are simple. I plan to stab this into my 68' Chevelle. I would like 450hp and TQ at the wheel if possible but I want it to be very street-able. I don't plan to take it to the track at any point. I'm not looking for light to light racing. I just want power when I want it. I don't want something that I wouldn't feel comfortable with my younger brother driving.
What I have is 02' 6.0 LQ4 with 317 stock heads and truck intake.
So my question to you guys is what Head, cam and intake combo do you guys suggest? Also I do not have a tranny as of yet but plan to get a 4L80e. From what I've read and have been told the 4L60e or 4L65e eventually are destroyed by the 6.0 block. I don't know if this is true not so I'm hoping you guys could also enlighten me on that as well.
MASS seller approved
for a strong daily driver, the 6.0 will do great with a 228-232 cam, tbss or nnbs truck intake and tb, long tubes, underdrive pulley, mill the 317s .030 to bump compression up to work with cam, 3600 stall and at least 3.73s. 6.0s kill trannys so either 6 spd or 4l80 is your best bet. feel free to pm with any ?s you may have....good luck with your project, rob
The following users liked this post:
Lq4foxbody (02-13-2023)
Is there a specific year or the 4l80 I should be looking for?
That said, Don't let any of that stop you and always persist. Good luck in your endeavors.
Homer_Simpson (07-06-2021)
LS1TECH & Trucks Sponsor
It will be tough to do on that kind of budget. The main recipe to picking up an LQ4 on a budget in my opinion is to try and get some 243 heads, a mid ranged sized cam, and full exhaust. The 243 heads will give a notable bump in compression which these motors need badly. I am not sure that 450 at the tire is attainable, but 400rwhp+ seems very doable to me.
WEll we know what kinda motor you got, what supporting mod's such as headers, etc do you have? The supporting crap is what eat's up the budget more so, than the cam etc... if your lookin for 450whp through a auto your gonna need a snotty cam, quite a bit of compression, and a really good converter.. I.e your budget is blown...
On a $2500 budget? is that including trying to get a trans? If so then your goals are far stretched unless you find some amazing deals. If you have 2500 to spend on the motor then longtubes,mill the stock heads,get a nice cam kit(with springs/rods) plus a tune could be done for that much.
Assuming you have the complete motor, computer and wiring harness you can probably find some 243 heads, have them freshened up with a valve job and set up with the correct springs for the cam you want to use. You should be able to get it all together for $2500 or less easy and make well over 400 at the wheels. The problem is going to be getting your swap parts like headers, motor mounts, transmission adapter and things like that in your total budget.
