installed zzp control arms
Old 11-06-2012, 02:36 PM
Moderator
91parkave's Avatar
Default installed zzp control arms
Very very satisfied with the new versions car handles great and was still able to retain the factory sway bar setup by unbolting ball joints and flipping them so the bracket wouldn't hit the sway bar. Eventually I'll upgrade to the gmpp front but that will be another day
Old 11-06-2012, 11:43 PM
supercatxr7's Avatar
What is improved over old design?
Old 11-06-2012, 11:59 PM
1CL3ANSUP3RSPORT's Avatar
Talking
They actually made a good set?
Old 11-07-2012, 04:17 AM
Moderator
91parkave's Avatar
tubing is way thicker on the revised versions i dont know why they havent advertised on the website but the new ones are simply beautiful. The rod ends they supplied come with rubber boots and greasable horizontal bushings
these were the old ones...hard to tell the diamater from crappy cell phone pics but they are noticeably thicker in person
OLD
NEW
Old 11-07-2012, 05:14 AM
gxplsfour's Avatar
Nice! Been looking at these for awhile, but had heard much good yet. Why didn't you use the boot on the front Heim?
I just did the AGX struts with the Dorman 127-100 sway bar replacement. Amazing improvement over stock! (mostly the sway bar).
Old 11-07-2012, 05:43 AM
wesdean78's Avatar
Excellent!
Old 11-07-2012, 10:32 AM
Moderator
91parkave's Avatar
I'll be doing coil overs really soon but I tore the boots on accident trying to count threads and make sure both rod ends were installed properlet
Old 01-02-2013, 03:48 AM
V8ImpSS's Avatar
Be careful! I was one of the lucky ones who had the old versions break on them while in the car moving. Luckily I was only doing 15-20mph but I still ended up with a bent control arm mount on the subframe.
Quick Reply: installed zzp control arms
