Corvette C5: How to shut off the tracktion system completely
Hi,
i don`t use the stock tracktion system.
I put the F45 out and also the controllers.
The tracktion system still works sometimes, also when i shut it off with the button and it looks that it takes timing out but i set the parameters on zero with the HP Tuner.
Is there any fuse or relais to remove so that the tracktion control doesn`t work at all?
Thank you
Thank you
Unplug the ABS unit plug, ABS ground wire, or any of the the front wheel speed sensors. The dash display will always be on, but the system will be inactive. My ABS pump went bad a couple fo years ago, so I just unplugged the unit and have been without issue, other than the dash light and warning on start-up.
Does the C5 computer have a section on traction control? I know on my car that section has 3 parts for traction control: spark, fuel and throttle. I can disable any or all of these, so in theory if I disabled all of them then the traction control system will be doing nothing to slowdown the car.
