5.3 truck heads on GTO LS2?
I have heard truck heads push more compression than car heads. I am wondering if 5.3 heads from a truck will benefit on a GTO LS2 since I figure the LS2 heads are built more?
LS1Tech Premium Sponsor
I would not swap to a 5.3L head away from the LS2 heads your engine came with. it would bump your compression up some, but the loss in flow would negate the performance gained from the compression!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
ok thats what I figured but wasn't sure
So should I do heads and cam build or turbo for more power on the LS2? It has long tube headers, cold air intake, computer programer? Pro's Con's?
