11.98 Stock Internal
Took the car last night to the track. This is the second time out with the new rearend, still getting used to it. Race weight is approximately 3300lbs including me (220lbs). The first time I ran it i couldn't make a complete pass, I kept having 2-3 shift issues. I did manage a 1.58 60ft on one of those passes though, but i think the car can do low 1.5s. I was told to overfill the trans fluid a bit to help it and I may have to bump to a 27" tire. But here are the results from last night. I did run a 26" hoosier drag with 27psi, any lower and it would bounce off the limiter.
60ft - 1.744
330 - 4.996
1/8 - 7.681@91.50
1/4 - 11.983@113
DA was about 800. I really think I can get a 11.4-11.5 time by dropping the 60ft and with negative DA of course.
60ft - 1.744
330 - 4.996
1/8 - 7.681@91.50
1/4 - 11.983@113
