How fast of a 1/4 could I do?
Old 04-12-2004, 10:09 AM
ActionJack's Avatar
Default How fast of a 1/4 could I do?
I went to the track for my first run ever and had the worst 60 ft of 2.2.
I ran the 1/4 in 13.5 at 103.
Realistically, if I get a good 60 ft how fast can I do the 1/4???
Old 04-12-2004, 10:46 AM
z98
z98's Avatar
Be more specific.
Old 04-12-2004, 10:56 AM
ActionJack's Avatar
Originally Posted by z98
Be more specific.
Well.... If I did a 1.9 60 ft how would that affect my total speed and time?
Old 04-12-2004, 11:03 AM
jRaskell's Avatar
Well, if you go from a 2.2 to a 1.9, there's 0.3 you've knocked off your quarter mile right there. On top of that you're probably only going to gain another tenth or two most unless you're having traction problems further down the track as well.
Old 04-12-2004, 11:05 AM
Rok
Rok's Avatar
I've heard that every .1 of a sixty you drop that's .15 at the 1/4.
so if you had a 2.2 sixty and ran a 13.5, then ran a 1.9 sixty the 1/4 would be 13.05 I think. hopefully someone will chime in with some more help
Old 04-12-2004, 11:26 AM
Iv_z28's Avatar
I believe the thumb rule is 0.2sec in a quarter for every 0.1 in 60'. Worked for me.
Old 04-12-2004, 12:41 PM
z98
z98's Avatar
There is no rule of thumb, YMMV!
With good tires and practice you might touch high 12's.
You should be able to beat a 2.2 with an auto.
How are you launching?
Old 04-12-2004, 12:45 PM
02WHITEZ's Avatar
i run a 13.10 at 109 with a 2.1 60 ft
lid, exhaust, headders
Old 04-12-2004, 01:05 PM
SMOKIN01TA's Avatar
this it the correct calculation for cars until you get into the 11's then it goes down a lil. so if you go from a 2.2 to a 1.9 you should loose a good half second. however you are in a auto so you should be doing better than 1.9s on drag radials. i think 12's are possible
Old 04-12-2004, 03:15 PM
ActionJack's Avatar
The problems I had.
1st I went through the water on street tires.
2nd I did not spin my tire enough.
3rd I have to get new tires they are at the bands in the tread to replace
4th I SPUN
5th there was a head wind and it was a bit cold (50 degrees).
If I can think of more reasons for my my crappy performance I will defiantely use them. I am sure the next time I go I will not be as nervous and will not make such stupid mistakes. I also need to practice launches at a rev.
Thanks for all the info so far.
Old 04-12-2004, 03:18 PM
NKAWTG...N
StoleIt's Avatar
having it a bit cold wouldn't hurt you, it would help. the air is more dense when it is cold out, thus oxygen is more abundent .
Old 04-12-2004, 03:24 PM
ActionJack's Avatar
Damn!
How about the tires not getting warm from the cold?
Old 04-12-2004, 03:37 PM
SMOKIN01TA's Avatar
Damn!
nope, they are street tires, if you get them hot they get greasy. all you want to do is spin them over enough to get the water out of the treads.
the water in the treads would definalty hurt you though
Old 04-12-2004, 05:04 PM
AK's WS6's Avatar
Well you have similar times to me when I was stock cutting 2.0 so for me it took a little better '60 and a lid and exahust and a good track prep (thanks Stanton!!!) to see 12's, I think you can get there with a little practice and some decent tires. FYI I never go through the water, just a quick lil burnout (on F1's) stage and pre-load the drivetrain just a little and let the lights drop!!!!
Old 04-12-2004, 08:01 PM
iB2slow's Avatar
i went 13.0 at 110 with a 2.3 60 and 8.8 in the 8th at 89 in m6 car its almost stock lid tune catback i think it will go 12.5 or a little better with skinnies and drag radials what do you all think
Old 04-12-2004, 08:07 PM
SMOKIN01TA's Avatar
look like you could go faster than 12.5 if you learn how to launch. and get some 1.8's
Old 04-12-2004, 11:10 PM
iB2slow's Avatar
yeah the car is strong but i cant keep the revs up off the line the clutch wont hold and i cant launch (still on f1's) it dynoed 338 355 that was the first time to the track in it to
Old 04-14-2004, 09:10 PM
Cheatin' Chad's Avatar
If you're on treaded street tires stay out of the water!
I cut a 1.9 w/my stock 1998 a/4 TransAm on 245/50/16 Yokohama Avid all season tires.NO WATER, 6-7 second burnout, No dry hops.
