TBSS cam only + nitrous= 10.77 Record
Old 11-10-2012, 12:11 PM
ronn25's Avatar
Default TBSS cam only + nitrous= 10.77 Record
Just wanted to share this with you guys here....cause I've learned a lot for reading this forum and talking with a few of the nitrous gurus on here, even though I don't post much. Thank you.
According to tbssowners website, my SS currently has the fastest stock block/heads (even still has stock truck intake) cam only record, and also the first TBSS in the 10 second zone still with a stock engine. I always figured if a cam only F-body with nitrous could run 9's. then a LS2 TBSS at about 4,400 lbs should at least go 10's. This was done a bone stock suspension and even has aftermarket sway bars still hooked up for the curves. Running a very tight yank 3200 10.5" converter unlocked.
I built a stand alone fuel system for it, running a Nitrous Outlet plate, and little second stage fogger. You can tell how much 60ft I gave up by rolling into it, it only pulled a 1.57, I'm currently upgrading the rear suspension now, and trying a different converter with triple disk to lock it up in 3rd. Hopefully will have some 1.4's 60ft's and get some sub 10.50's.
Attached Thumbnails TBSS cam only + nitrous= 10.77 Record-img_0428-modified.jpg
Old 11-10-2012, 12:39 PM
UsmcAlston's Avatar
Great times how much spray?
Old 11-11-2012, 05:15 PM
Carter01's Avatar
Congrats man, excellent sleeper!
Old 11-11-2012, 05:51 PM
Gordon0652's Avatar
Spray? How much? like a 250 shot?!
Gordon0652's Avatar
And I'm guessing the transmission is built?
Old 11-11-2012, 10:43 PM
ronn25's Avatar
Thanks, Carter your one of the guys here that helped me. Once I have the suspension upgraded and a the triple disk converter in, I may go up on the shot! I was spraying with the converter unlocked, and had the window switch set to turn off at 6300 and she crossed the traps at 6400rpm. So all is very conservative, 14 degrees of timing.
Trans is local built 4L70, but I haven't sprayed it thru the shifts yet.
It made 412hp 417 ft lbs at the wheels on motor, and laid down 635 rwhp on the spray, with over 600 ft lbs the entire pull with a peak of 659 ftlbs.
Old 11-11-2012, 10:48 PM
ronn25's Avatar
And yes sleeper that still does work....lol I still tow with it on occasion.
Attached Thumbnails TBSS cam only + nitrous= 10.77 Record-img_0122-modified.jpg   TBSS cam only + nitrous= 10.77 Record-imag0727-modified.jpg
Old 11-12-2012, 05:51 PM
Gordon0652's Avatar
That is so awesome!
Old 11-12-2012, 06:57 PM
Old School Heavy
speedtigger's Avatar
Awesome.
Old 11-13-2012, 01:23 AM
navyblueSS's Avatar
Nice!
Old 11-13-2012, 08:37 PM
ronn25's Avatar
Thanks, new converter is going in tomorrow, and just put adjustable control arms to get rid of the wheel hop. Hopefully some better times are on the way.
Old 11-15-2012, 09:08 AM
Neal@NitrousOutlet's Avatar
Thats an amazing time. Its fun watching a big car/truck move out!
Old 11-15-2012, 11:49 AM
ronn25's Avatar
thanks, yea it takes a lot of torque to get 4400+ lbs moving. Someone told me I should go to direct port, I said "Why? I have a Nitrous Outlet Plate" Lol
Old 11-22-2012, 01:41 AM
turbo freak's Avatar
Very nice numbers!
I have a ´03 4x4 silverado with the 5.3 engine, 444 comp cam, valve springs, open exhaust, and ZEX LS big shot nitrous system with a stand alone fuel cell. I hope i could get close to that numbers man, awesome!
Old 11-27-2012, 12:02 PM
Zfan's Avatar
That's incredible, congratulations on making that big girl move!
Old 11-27-2012, 03:23 PM
TeEnAgE pHeNoM's Avatar
I've seen this thing run in person. Moves out hard. Hopefully it will go faster the next time out.
Old 11-27-2012, 07:05 PM
ronn25's Avatar
Tried a different converter (triple disk) about a week ago, it was way too loose, but managed a 10.73 at 126.5mph on a 1.50 60ft. Getting it restalled now, hopefully run better next time out.
Quick Reply: TBSS cam only + nitrous= 10.77 Record
