ls1 and lq4 flex plate...is mine correct?
just picked up a lq4 out of a 05 2500. looking to bolt up my SS3600 stall and flt 4l60e trans. i noticed that the flexplates look a little bit different, and figured i might as well post up to find out if i will have any issues here...? thanks in advance.
5.7L LS1:
6.0L LQ4:
5.7L LS1:
6.0L LQ4:
I did search and read that they should work since the lq4 is post 00. The ls1is out of a 98 if that matters. What I read it should work but I just want to check since the flexplate actually look different.
My 5.7 is completely flat, but the lq4 is sunken in a little bit with raised converter mounting points. (well, that's what it looks like at least... Lol)
Can any one confirm if it will work or if something needs to be done to make it work, this is a dd and need it on the road.
If the diameter, bolt pattern, depth is the same, no reason why it wouldn't work
