Another successful track outting
Old 11-11-2012, 08:57 PM
dschmittie1's Avatar
Default Another successful track outting
Well I went to Cecil this Saturday to make some more passes in the car and see if I could run an 8 on a track that doesn't hook as well as MIR
1st pass off the trailer and waiting out a small rain delay. Exact same tune up as my 8.89@154 pass at MIR 2 weeks Prior. Car spins hard on the launch. I ran it out the back door just to make sure things where ok
2nd pass I dropped the launch psi down to 7 psi from 9psi results
60' 1.476
1/8 5.845@124.68
1/4 8.989@156.15
car felt good launch seemed a little dog is so next pass I raised the launch boost to 8 psi
3rd pass spun hard again and aborted the run
4th pass I dropped the launch psi back down to 7 psi but I upped the down track psi to 15
60' 1.384
1/8 5.690@125.60 <best 1/8 mile
1/4 8.810@157.34
5th pass Same setting as last pass. Spun again and aborted
6th pass dropped the launch rpm by 100 rpm just to help traction
60' 1.414
1/8 5.703@126.41
1/4 8.807@157.91
7th pass raised the down track boost to 16 psi
60' 1.415
1/8 5.704@126.93
1/4 8.796@158.61 <--new best 1/4 pass
I had a great day and I am more than please with the results from the car. I am happy to put the car away for the winter now and no the I have exceeded my goals for the year with the car.
Video from Saturday is still uploading I will post it up once done
Here are a couple pics that Denmah took.
And a pic I took at home after cleaning it up and before going on a cruise
Old 11-11-2012, 09:01 PM
9sectruck's Avatar
damn thing is moving, whats the specs again if you haven't be asked over and over
Old 11-11-2012, 09:09 PM
http://www.youtube.com/watch?v=olIpX...ature=youtu.be
Old 11-11-2012, 09:12 PM
385 ci ls2 AFR 205 heads, VA speed cam, S88 turbo and E85 16 psi car weight 3410
Old 11-11-2012, 09:15 PM
9sectruck's Avatar
does the block have aftermarket sleeves to get that cubic inch
Old 11-11-2012, 09:20 PM
Nope stock ls2 block with a 3.8 in stroke. AES did the short block
Old 11-11-2012, 09:22 PM
Cam72aro's Avatar
Damn Dan. You impress me every time with the results. It keeps getting better and better. If the track can handle it at the hit and you up the down track boost the car will be even faster. You can definitely put it up knowing that it has met your goals.
Old 11-11-2012, 09:27 PM
Thanks yeah I am only imagine what it would have run at MIR
Old 11-11-2012, 09:29 PM
9sectruck's Avatar
DAMN!!!!!! that thing moves 40ft and flat f----- moves
Old 11-11-2012, 09:31 PM
Yeah the prep was a little questionable and my radials are basicly done
Old 11-11-2012, 09:39 PM
9sectruck's Avatar
gears? 315 325?
Old 11-11-2012, 09:44 PM
3.25 gear ratio and 325 50 15 MT radial. was going through the traps around 6600 rpm
Old 11-11-2012, 09:45 PM
o2camaross's Avatar
Very Very Impressive!! Congrats. That thing has more in it too haha!! What stall?
Old 11-11-2012, 09:46 PM
rotary1307cc's Avatar
nice!
Old 11-11-2012, 09:49 PM
9sectruck's Avatar
im shootn for 150-155mph with my car with a 3.50gear and a 325 radial. damn impressive man, hope my turd goes close to your et/trap when im done, again congrats, thanks for the info
Old 11-12-2012, 03:18 AM
venom ws7's Avatar
Thats a perfect street car right there congrats man.
Any interior pics? Did you gutted all the all of it?
Mid 8s is very possible on 20lbs
Old 11-12-2012, 03:56 AM
wilfredes's Avatar
Old 11-12-2012, 05:39 AM
Yank 3400 stall
Originally Posted by rotary1307cc
nice!
Thanks guys
I will have to take some but Those passes still had all the factory plastics in but only the drivers seat. Still the factory seat. I also don't have the radio or HVAC any more. So it is gutted some but still looks relatively stock inside
Old 11-12-2012, 07:04 AM
a4ls2goat's Avatar
Very nice job!
Perfect street car.
Quick Reply: Another successful track outting
