3 bolt cam on 2011 VVT Silverado need some advice
Old 11-12-2012, 11:47 AM
sleepy_boy1's Avatar
Default 3 bolt cam on 2011 VVT Silverado need some advice
Guys im installing a 3bolt cam on a VVT Silverado, i have the DOD Delete Kit which includes the 3bolt sproket, ls2 valley covers, new lifters, and, my question is do i need to change the cam sensor? or will the car start up? im not sure i need some advice.... canthe tuner tune out the VVT with HPT
Old 11-12-2012, 11:50 AM
85MikeTPI's Avatar
Same cam sensor will work. Did you get a new front cover with the delete kit? It should be needed since the cam sensor will need to be closer to read the 3-bolt gear instead of the phaser.
HPT beta can turn off VVT
Old 11-12-2012, 12:18 PM
whats the cover from? what vehicle?
Old 11-12-2012, 01:00 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
http://www.texas-speed.com/p-724-vvt-delete-kit.aspx
You'll need the VVT delete kit as well!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 11-12-2012, 01:36 PM
will i need to change the chain dampener or can i keep the one on the truck now?
Quick Reply: 3 bolt cam on 2011 VVT Silverado need some advice
