444" Ls7 w/ Dailey Dry sump system
Category: Engine - Complete Motors
Price: $25000
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): MI
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
Brand New LS7 Block bored to 4.135 and Diamond Honed.
Comp Star 6.125 H-beam Rods
Callies 4.125 stroke crank
Diamond coated pistons 10cc dome.
DLC coated H-13 wrist pins.
Total Seal gapless 1.5mm top ring, Napier 2nd, low tension oil.
14:1 compression
Hand ported LS7 heads(ported at Mast)2.200 titamium intake, 1.61 S.S exhaust (flow 375 @.650 lift)
Pac valve springs, with tool steel retainers
Fully Hand ported matching Mast Intake.
Custom Grind CompCams Hyd. Roller 264 in 271 ex 113lsa 110icl .684 lift
LS7 rocker with comp upgrade.
3/8 dia Trend pushrods
Jessel Belt Drive
Coated bearing, Main, Rods, and cam
SV1 Carb.
Dailey Dry Sump oilling System w/ Billet Oil Pan.( Pump And pan was over $5000 new)
Motor is all new, should easily make 800+hp, I think It will make 850+ no problem.
Motor is all new ready for the dyno. Will dyno next week.
This motor has the best of everything, no expense spared!!!!!
Motor was built at Holbrook Racing Engines in Livonia Michigan.
