use my 226/234 113+3 cam for my turbo motor???
Old 11-12-2012, 11:04 PM
got-a-ls1's Avatar
Default use my 226/234 113+3 cam for my turbo motor???
so i dont really want to sell this cam and i was trying to do some research on how well it would work in a turbo app. i currently have the ls6 cam which does work great, but im going back to auto and wouldnt mind getting a little lope back. i see most "turbo" cams dont really have much split...
Old 11-13-2012, 06:46 AM
LilJohn's Avatar
Install it on a 108 intake centerline instead of a 110... and let it eat.
The 113 puts a tick too much overlap into it....but itll rumble at idle some if you like that.
Old 11-13-2012, 10:29 AM
jridenour31's Avatar
How about a 230/234 112+4? Cam only ls1 with a 7675.
Old 11-13-2012, 07:50 PM
Sales@Tick's Avatar
Too much overlap and too small of a turbine for that much overlap.
Old 11-13-2012, 08:39 PM
Lol that's what I was afraid of, just trying to be cheap. How would it work with a 96mm turbine s475? Streetability isn't a concern as much as straight line performance.
Old 11-13-2012, 11:12 PM
LilJohn's Avatar
Itd work fairly decent if you made some adjustments for it. It has too much overlap for a ls6 style intake. It will rumble pretty good at idle. It looks like some of my blowthrough carb cams i do. They like a little more overlap. Pulls on the boosters a bit harder so you dont have to overjet to get the fuel curve right.
That cam would work better with a single plane intake and installing it on a 106 centerline. If you are running a regular intake... Id like to see the static compression bumped a tick to counteract the extra overlap. With small heads and a long runner intake that overlap should allow it to rpm pretty good even with the ivc closing as early as it does.
Id run it.... its way better than an LS6 cam. Heh
Old 11-14-2012, 09:09 AM
Sales@Tick's Avatar
I agree with John, for a S475 T6 1.32 it could work.
Quick Reply: use my 226/234 113+3 cam for my turbo motor???
