Tuning for T-56 transmission swap.
Okay, I have a T-56 swapped in and want to make sure I have the trans settings as close as possible.
I have a GTO T-56 so the ratios are:
2.97/2.07/1.43/1.0/.84/.63
For my car, I have a 3.42 rear gear and running 275/40/R17s for tires.
What all do I need to change on the speedometer tables? This is running a PCM flashed with the T-5 tables from the dealer. It seems to be a little bit off, but kinda hard to tell since nobody around here does the speed limit.
Current settings are:
GTO Tables look like this:
Code:
General VSS Pulses Per Mile: 43700 Rev - Trans 10.5703 Final Drive Ratio Drive Sprocket Ratio 0.000 Trans Revolutions/Mile 0.000 Gear/Tire Calc Current: 7.85 Auto Scale Transmission Tables: Yes FWD: No
Code:
General VSS Pulses Per Mile: 47992 Rev - Trans 40.0000 VSS Output Pulses Per Mile: 10020 Mile - ABS: 128000 Final Drive Ratio Drive Sprocket Ratio 3.46 Trans Revolutions/Mile 2448.5741 Gear/Tire Calc Current: Tire Size: 24.72 Gear Ratio: 3.46 Auto Scale Transmission Tables: Yes FWD: No
