Huron Speed Turbo guys, what are your plans?
Hey guys, It looks like there's a lot of us and not much has been said, I was wondering what's your setup and what are your plans?
My setup is a 347ci forged engine, 317 ported heads with inkonel valves, EPS cam, 9:1Cr. Right now I 've got a single 255 walbro but might need to get double 340's, and will need to upgrade my 42lb injectors for sure. Been thinking about getting a TC78, but have heard a lot of guys say its too small of a turbo for a 347ci forged engine, the reason I was thinking on using the TC78 is because I'm tunning my car (efilive) and think tunning a small turbo will be easier and safer since I'm no expert, but I'm totally new to turbo stuff and Im open to suggestions.
I would appreciate to hear any input on my setup or any other stuff and would love to know what everyone is planning to use
Cheers
Cheers
I have a forged 370 and just ordered the turbonetics 7675. It is going to be a street car with a t-56. https://ls1tech.com/forums/forced-in...rbo-build.html is my build thread if anyone wants to check it out. I planned on going with a custom kit but I just couldn't pass up this group purchase deal. I'm glad I went this route. Can't wait to see all of the other Huron Speed builds.
LS1
224r cam PRC .650 springs
stock 853 heads
37 lb racetronix injectors
Racetronix fuel pump with hotwire
Huron speed turbo kit with turbonetics tc76mm
STOCK 4l60e
custom street tuned
I plan on running low boost to start, around 4-5lbs so the stock transmission will last awhile. That should make around 480rwhp or so. My goal is to trap 120-124 on 4lbs. Than once the tranny goes I'm going to get a built flt lvl 4 tranny and up the boost to 8 psi with meth injection. My tranny lasted though nitrous so I hope I can get some good miles on it with 4 lbs of boost
BTW mine is also a pewter Z28
My race is at the very end.(4:50) There's 2 races.
I never answered your question though. My only plans are to put a better clutch and rear end in the car, then start pouring on the boost.
LS1
stock 853 heads
STOCK 4l60e
custom street tuned
stock 853 heads
STOCK 4l60e
custom street tuned
I was thinking on getting the Lonnies Performance dual pumps, I've only heard good things about them!
3.42 rear gear, and I'm running E85 so my duty cycles are going to be much different than yours. It runs strong. The only vid of me racing is against a 500 rwhp S2000
http://www.youtube.com/watch?v=aN7CbC3ksPM&feature=plcp
BTW I love the quiet exhaust sound from the turbo at WOT!!
Here's my plan for now
Stock short block
Ls6 intake
Brute speed cam ( car was procharged)
Supporting valve train/ oil pump.
PT7675 .96 A/R
Persicon 46mm wastegate
Tial 50mm bov
Twin 340's intank
Fast fuel rails
Motron 60's
Fuel system and suspeion was already done before making the switch to turbo.
I Plan on running around on 550 600 hp for a lil while and then finish up my 347 im gathering parts for. Oh also would like to maybe tune it myself we will see
Stock short block
Ls6 intake
PT7675 .96 A/R
Tial 50mm bov
Twin 340's intank
Fast fuel rails
Motron 60's
Well.. Im going to see how it will fit on my car to start!
Texas Speed forged lq4/9 (not decided if i want to bite the bullet and go 402ci)
light p&p 317s
PT7675 or 7875(or pt88)
80lbs injectors
huron speed twin fuel pump kit
huron speed piping (will be painting intercooler)
Very mild.. cam. I want it to be undetectable with it being a little more boost friendly
Turbosmart eboost2
Will be tuned by Frost
and of course all of the supporting mods
Then pretty much replace whatever breaks first. My guess will be...
Rear then clutch and then my t56. The transmission was rebuilt around a year ago and the clutch is a centerforce dual friction. It should last long enough until i can find the cash to upgrade. My rear is only a matter of time.. even on my 245s now.
light p&p 317s
80lbs injectors
Turbosmart eboost2
Stock shortblock LS1
Stock heads(Dual springs)
Stock cam
Dual 255's
60lb injectors
TH400 RMVB w/ Brake
Stock 3.23 10 bolt(We'll see how long that lasts)
Undecided on turbo. Currently have an on3 76mm
8-10lbs on 93.
Hoping to go mid 10's @ 125-ish
Stock cam
Dual 255's
60lb injectors
TH400 RMVB w/ Brake
8-10lbs on 93.
Haven't gone in on the kit but I'm planning to real soon.
Aes 390ci
853 heads
Tc-78 (temporary turbo)
Shooting for 650 wheel for now. Still on stock t56 and 10 bolt lol. After I fix those week links, the plan is a GT-88 and going for 1000whp. Hopefully my trans and rear will hold up at 650wheel as long as I don't launch haha.
Aes 390ci
853 heads
LS1Tech Sponsor
Cool thread! Nice to see everyone's combinations!
Jon
Jon
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Stock LS1
Stock heads (also dual springs)
LS1 intake (need to replace this)
Custom ground cam from Tick
Dual 255's
60 lbs injectors
Stage 2 tick T-56
Some kind of stage 3 clutch (whatever I can get best deal on lol)
Stock 10 bolt ( I know) with 3.42s
Turbonetics 7875 .96 ar
xs power 50mm BOV
Turbonetics RG-45 WG
Boost controller undecided on which one yet
I will be running around 10 psi daily on a (safe as can be on boost) tune. 93 pump but may convert to e85 later on. Pretty sure I'm forgetting some things but oh well. And I need to find a good tuner around southwest Michigan area.
Dual 255's
60 lbs injectors
Stage 2 tick T-56
xs power 50mm BOV
Read all your comments, when we're finished would like to see the differences in HP between the stock bottom cars and the forged ones, difference may not be much.
Is your huron speed twin fuel pump kit already installed? U got any pics? Are you using a hobbs switch? BTW good luck, hope you dont have much trouble fitting it!!
light p&p 317s
80lbs injectors
Turbosmart eboost2
light p&p 317s
80lbs injectors
Turbosmart eboost2
Aes 390ci
853 heads
Aes 390ci
853 heads
rebuilt LQ4
Fast 102/102
ported west coast 317's
custom grind cam from comp.
Huron Speed hot side
TC78/68
racetronix fuel pump and hotwire kit, ima needa upgrade that
got 48# injectors right now but gonna upgrade that as well
converting from A4 to M6 (personal preference)
stock 10 bolt with 325 hoosier D/R thats gonna go boom
gonna aim for 600 cant wait to finish, I guess im kinda half way with this.. still need a bunch of little things here and there
Fast 102/102
TC78/68
Iron 5.7 with Mahle forged pistons stock crank and rods, arp rod bolts
317 heads with isky springs
Ls1 cam
Fic 1000 injectors and walbro 485 pump
On3 76
Going on dyno Friday! Should be around 650 to the wheels I hope
I forgot to mention it will be on e85
Ls1 cam
On3 76
