Fs/ft 02 ta ws6, h/c/i, m6, 447/400
Year: 2002
Make: Pontiac
Model: Trans Am
Price: $15000
Mileage: 56057
Private or Dealer Listing: Private Listing
Location (State): RI
Color: Black
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Factory Options:
WS6 Ram Air performance package
T56 6Spd Manual transmission
T-tops
Leather interior
Power Seats
Exterior Modifications:
-Flat Black Blackbird stripes Hood and Spoiler
-Flat Black nose bird
-Last of the Breed Badging
-Flat Black filler panel
-Eurolights H7 Headlight conversion
-DDM 35w 6k HID Fogs
Interior Modifications:
-Blackbird Gauge overlays
-Hurst Classic White ball
Performance:
-Tuned by Slowhawk
-Rapid motorsports Dominator 346CI blueprinted engine
-New LS6 block
-New ELESJUAN crank
-Scat Forged H-beam rods
-Diamond forged pistons 11.5:1 C/R
-Childs Albert plasma moly rings
-Clevite bearings
-ARP main studs
-ARP rod bolts
-LS6 valley pan/pcv
-Comp Cam 620/623 235/239 111LSA
-Morley lifters
-Rollmaster double row timing chain
-Ported LS6 oil pump
-Cometic head gaskets
-ARP head studs
-Chromoly pushrods
-Trickflow 215CC heads
-Dual valve springs
-Titanium retainers
-Harland sharp 1.7 rockers
-Catch can
-SLP lid
-K&N filter
-Z06 MAF
-NW 90MM T/B, black anodized
-FAST 90MM Intake
-Racetronix 255LPH pump
-FAST Aluminum fuel rails
-Ractronix 42LB/hr injectors
-Kooks 1 7/8 LTs
-Kooks ORY
-Magnaflow Cat back
-QTP e-cuout
Suspension/Chassis:
-AFCO double adj rear shocks
-QA1 shock relocation brackets
-Spohn LCA relocation brackets
-Spohn Chromoly SFC, red powdercoat
-BMR upper/lower Front Control Arms, red powdercoat
-BMR Tourque relocation kit/trans crossmember
-UMI driveshaft loop, red powdercoat
-BMR Drag Bar, red powdercoat
-BMR non-adjustable torque arm, red powdercoat
-Spohn non-adjustable chromoly LCA's, red powdercoat
-BMR on car adj PHB, red powdercoat
-Baer Eradispeed rotors NEW EBC red stuff pads up front, hawk pads out back
-SLP linelock
-Earls stainless steel braided lines
Drivetrain:
-Slowhawk lvl 2 T56
-Lou's Short stick
-Pro 5.0 Shifter
-Monster Stage 3 clutch
-McCleod blowproof bellhousing
-Tick Master cylinder
-Spohn HD 3.5" Steel driveshaft
-Moser 12 Bolt, 33 Spline axles, T/A girdle, ABS
-Full Spool
-4.30's
-Prostars 15x3.5 with nexens and 15x8 27.11.5 QTPs
Electronics:
Apline deck
