REDUCED Parting out 03 LS6 from Z06 Vette with 50k
Category: Engine - Complete Motors
Price: $0
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): LA
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Engine was removed from a 03 Z06 with 50k. #6 dropped a valve and destroyed that cylinder in the block and on that head.
Pictures and part numbers of everything available upon request. Some parts not listed may also be available (camshaft, oil pump, front timing cover, timing gear and chain not available) like gaskets, engine plugs, sensors, bolts, main caps, etc. PM, text, call, email, morse code, smoke signals - Cody @ 225 715 055 five codymlee@yahoo.com
Free shipping if paying the asking price.
Engine Coolant Temp Sensor $15
Block off for oil sensor (2 bolt plate above oil pan on driver side that is commonly tapped for oil for turbo setups) $20
Oil PSI Sensor $15
Engine Block Plugs (3) and Dumbbell in oil galley $12
Main Caps (set of 5) with Bolts $35
Crankshaft $115
Pistons and rods (7 rods and 6 pistons) $90
Complete Uncut Engine Wiring Harness $160
DBW Throttle Body SOLD
Fuel Rail SOLD
LS6 Valley Cover with valve cover grommet & hose SOLD
Lifter Trays (set of 4) SOLD
Knock Sensors with Harness SOLD
Camshaft Sensor SOLD
Crank Sensor SOLD
Rocker Arms SOLD
LS6 Intake SOLD
243 Heads with valves & 15 springs (no rockers) - 1 head has one cylinder destroyed (check pics below), other one is perfect. Priced as 1 complete head and get other head for free - SOLD
Rocker Arm Shafts (set of 2) SOLD
Valve Covers (set of 2) SOLD
Crank Pulley (has some marks from removal) SOLD
AC Compressor Bracket with idler SOLD
Rear Engine Cover SOLD
Oil Pan with pick up and tray SOLD
Motor Mounts (set of 2 with bolts) SOLD
(8)Injectors (28lb I believe) SOLD
Coil Packs with brackets & harnesses (set of 8) SOLD
Water pump with thermostat SOLD
Misc sensors, gaskets, and bolts are also available. Feel free to ask about anything else.
