Need Help on Removing MAF
hey there noob here i orderd a slp lid for my 01 t/a ws6 i got everything off that i needed to remove except the MAF it is on there pretty tight i have tried everything heating it with a blow dryer etc. is there a way you need to take these out or should of it allready budged by now? also the IAT sensor came out pretty easy but i broke the rubber grommet in the process are these easy to find at any local parts store or will i have to make it fit my own way?
can some one please help me out?
im stuck i dont want to break the housing where the maf sits either
So the MAF is still stuck to the stock lid?
It took me a good 10-20 minutes to get that thing off... I basically sat down and held the lid between my thighs, I then used my left hand to hold the blow drier and used my right hand to do a twist-pull motion.. Mine was stuck on pretty bad :o
Good luck!
Good luck!
