3.8 a4 to 5.7 t56 help
hey, 01 v6 a4 dropped out replaced with a 99 ls1/t56. I got the drivetrain swapped and am in the process of making it run. I did the c101 to c105 trick but it does not appear to have worked. The picture attached is my attempt at tapping the two wires. Bank 1 injectors have 12v bank 2 has nothing. Im wondering if i tapped the wrong wires? Would any one be able to elaborate on the difference between v6 and v8 wiring. The v6 fuse block is wired for injector bank 1 but not 2 which is the part i don't understand. I read on here about moving the engine control wire to the injector 2 spot but after flipping the fuse block the injector bank 2 position has a pin in the block but no wire in the pin. I know ls1tech has a bunch of smart guys and gals so anyone willing to help id greatly appreciate it.
