ls2 timing chain slack
I bought a new ls2 timing chain setup and it seem like there is a lot of slack in it. I found a thread where people went back and forth some use it some dont. Is this normal? My block is drilled for a tensioner but it did not come with one. any ideas?
I just bolted up the Trickflow Bracket that allows ya to use the LS2 dampener to my LQ9, it's a nice piece but I thought it would've put some tension on the chain, seems like if the dampener (oem LS2) was a little wider it would eliminate
all the slack..but i'm know engineer. I guess it does keep the chain from "whipping" under load though.?
By far the most important application for the t-chain dampener is road racing as the engine sees extended periods of time in the 3000-4000 rpm range and there are some wicked harmonics created by the engine in that rpm range that kill t-chains ,,,,,,,,,,,having said that it will provide peace of mind if nothing else .
