Stock Rockers with 144k miles and Comp Trunion Upgrade?
Old 11-15-2012, 10:34 AM
Super Hulk Smash
JakeFusion's Avatar
Default Stock Rockers with 144k miles and Comp Trunion Upgrade?
Would it make sense to install the Comp Trunion upgrade into a set of stock rockers that are at 144k miles?
Or would it be smart to buy a new set of rockers and install the trunion upgrades into them? Looks like I can get a set for $170 from gmpartsdirect shipped. Ugh.
Old 11-15-2012, 10:44 AM
redbird555's Avatar
I would just go ahead and do the upgrade on the existing ones. theres nothing to the rocker arm other than the solid steel and needle bearing.... if you replace the bearing then you practically have a new rocker minus the fact that the steel body is the same...
Old 11-15-2012, 10:52 AM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
I agree 100%. The rockers you have now should be perfectly fine to do the trunnion upgrade on.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 11-15-2012, 10:53 AM
Super Hulk Smash
JakeFusion's Avatar
Thanks
Old 11-16-2012, 11:33 AM
427's Avatar
Rockers major wear point is the valve tip. I would buy the new rockers at 144K, but at least look at the tip for damage before putting money in them. My PU had 107,000 when I looked them over, 3 were visibly worn at the tip so I replaced the set.
Kurt
Old 11-16-2012, 11:37 AM
wildcamaro's Avatar
The steel in the rocker body can also eventually fail because of fatigue, but if the 144k miles were on a stock cam I wouldn't worry if the tips are good. Now if the rockers had 50k of high rpm abuse I would prob replace them.
Old 11-16-2012, 11:44 AM
Super Hulk Smash
JakeFusion's Avatar
Hmm. Well it's all stock, but I'm the third owner. So I have no idea really what kind of abuse it's seen.
My concern was metal fatigue and valve tip wear.
Old 11-16-2012, 01:46 PM
Grimes's Avatar
I would just mod the ones you have now. I don't think you are anywhere near the fatigue limits of the rocker.
Old 11-16-2012, 03:02 PM
chevybayboy's Avatar
Replace them now if you don't plan on doing any upgrading later if you plan to can the car or go bigger heads later just do it then that's what I would do
Old 11-16-2012, 03:11 PM
ThumpnZ28's Avatar
If they look good, run em.
Old 11-16-2012, 03:33 PM
Super Hulk Smash
JakeFusion's Avatar
Well the plan is to do heads/cam and swap out the trunions during the install.
Old 11-16-2012, 03:59 PM
Id do the new ones with the upgrade.. if I would have know about this upgrade before butin my adtermarkets I would have done new with upgrade
Quick Reply: Stock Rockers with 144k miles and Comp Trunion Upgrade?
