Copper coating ls9 head gaskets
Copper coating is for water leaks, it's not going to help a bit with combustion pressure. GM gaskets seal well on most block surfaces. Other gaskets tend to leak more if the deck surfaces are not REALLY smooth so coper spray will help here. You should always be shooting for a nice low RA number(surface finish) on anything high performance with MLS gaskets.
I actually posted a thread just like this last year and I got a pretty firm NO from some of the bigger names in this section. Made since not to since the ls9 gaskets come factory with a thin coat of rubber around the holes. The felpros and the cometics I had used before were just metal on metal do I coated them. But with the ls9s I say no. However obviously others had and have had great success with it so I say you'll be fine either way...
