Got the hot side to the turbo started today.
Old 11-15-2012, 05:50 PM
Chevyscoot's Avatar
Default Got the hot side to the turbo started today.
Started on plumbing the hot side of the turbo up, and managed to get to the turbo done. I'm a little worried about hood clearance, JK it's for a boat application. Let me know if you guys see something wrong this is my 1st turbo build and I am stoked!!
Attached Thumbnails Got the hot side to the turbo started today.-hot.jpg   Got the hot side to the turbo started today.-side.jpg   Got the hot side to the turbo started today.-exhaust.jpg
Old 11-15-2012, 06:00 PM
alexcoreas's Avatar
I see something wrong. You didn't mention which welder your using lol.
It looks cool dude.
Old 11-15-2012, 06:07 PM
Chevyscoot's Avatar
It looks cool dude.
It's a old dinosaur millermatic 35 and I love it. Thanks man
Old 11-15-2012, 06:48 PM
jridenour31's Avatar
How are you routing the downpipe? Looks good other than the crush bent pipes but they will work fine.
Old 11-15-2012, 06:55 PM
Chevyscoot's Avatar
I'm putting a 4" 90 on the back of the turbo and will run stainless flex to the resonator.
Old 11-16-2012, 06:53 PM
Chevyscoot's Avatar
Here is a pic of the downpipe, it will have stainless flex from here out.
Attached Thumbnails Got the hot side to the turbo started today.-downpipe.jpg
Old 11-16-2012, 07:29 PM
Nice, should run well.
Old 11-16-2012, 09:01 PM
95bowtie's Avatar
Thats cool, what kind of boat is it going on?
Old 11-16-2012, 09:29 PM
Moderator
denmah's Avatar
sweet
Old 11-17-2012, 07:47 AM
Old Geezer's Avatar
Wastegate being plumbed just below the turbo may limit the minimum boost you can attain....
Old 11-17-2012, 04:08 PM
Chevyscoot's Avatar
Thanks man, it's going on a small Airboat.
Old 11-17-2012, 04:10 PM
Chevyscoot's Avatar
should I have brought it down further?
Old 11-23-2012, 02:38 PM
Chevyscoot's Avatar
Hot sides ceramic coated now and I just like from the turbo to the intercooler.
Attached Thumbnails Got the hot side to the turbo started today.-blowboat.jpg
Old 11-24-2012, 08:51 AM
Old Geezer's Avatar
Default Looks to be..
a bit late, seeing you have coated them....
To get max control of the min boost, I'd suggest you would have plumbed a pipe from each feed pipe, [lower on the pipes], up to a common flange for the wg...
Old 11-24-2012, 01:21 PM
Chevyscoot's Avatar
I'll change the front side to the turbo later if it gives me any trouble. Thanks for the info tho.
Old 11-26-2012, 07:47 PM
Chevyscoot's Avatar
Finished up all the plumbing today.. After I changed the injectors from stock to Seimens DEKA IV 60lb fuel injectors I fuel soaked the plugs! I cut the fuel from stock to about 65% and got it to crank and run.
Attached Thumbnails Got the hot side to the turbo started today.-turbo3.jpg   Got the hot side to the turbo started today.-turbo4.jpg
Quick Reply: Got the hot side to the turbo started today.
