Sudgestions on cam swap?
Ok I have an 09 hummer h3 alpha, with a 5.3, and 799heads, what cam would work best? I found a megadeath cam( 244/242, 610/612) , I also found a cam from mast performance (I don't know the specs) . Does anyone have any recommendations?
Well, right now I am open for any sudgestions, I have thought about pulling out the 5.3l and replacing it with a 6.0, or a 6.2. ,and yes I realize that I will need to replace my converter as well.
If I could just unleash power out of my 5.3 I would be happy. It does have 799 heads from the factory, and since this is a "detuned" 5.3 I imagine the cam was where the did it,
You need a cam that has good low-end power for your hummer h3. Take a look at the CompCams #54-455-11 (Int. 215 Ext. 223 Int., Lift .604 Exh. .610 LSA 112° ), or the Speed Inc. SI-Torque Cam (214/220 .559/.564 111.5 LSA). I'd also look at the Lunati Voodoo #20540713 (217/223 113+4., lift .549"/.549").
