New style rear main install questions
I installed my rear cover and new rear main last night. When I was tapping the new seal into the rear cover the plastic insert fell out. After looking at it for a few seconds it looked like I could slide the cover back in with no issues and install it. I put the cover over the crank and pushed it on and it the seal seams to be sitting on there fine. Has anyone else had this problem? I did not lube the seal face like the gm manual instructs. Did your seal leak after you got the car running?
Thanks for the help
Thanks for the help
Thanks for the help
Thanks for the help
