How to make seperate fuel system for nitrous.
Old 04-12-2004, 06:05 PM
JESSIE's Avatar
Default How to make seperate fuel system for nitrous.
I have a TNT F1 kit and would like it to have its own fuel system so I can run some race gas in it and up the jets. I am going to put the tank on the driverside in the vicinity of where the fuse boxes are (I will probably move the fuse boxes to around to make room) now what do I need as far as fuel pump and wiring. I know a lot of people are starting to due this so any info or help would greatly be appreciated. Thanks Jessie
Old 04-12-2004, 06:32 PM
JoSeY's Avatar
I would personaly put it on the Passenger side where you just do a battery relocation kit to the back...put a 1gallon fuel cell where the battery was, use the Blue high pressure/high volume fuel pump...then plumb a line from the pump to the fuel sylinoid.
pretty easy to do....
Old 04-12-2004, 07:25 PM
The Bull
DERTY's Avatar
You can do it on either side. The fuse blocks can be a small challenge, but it would work. Here's a writeup I did that should cover most of your remaining questions. http://www.derty.org/?body=Installs&content=directport
Old 04-12-2004, 10:05 PM
Quickin's Avatar
Is that a DP set up?
Old 04-13-2004, 07:57 AM
The Bull
DERTY's Avatar
Yes it is.
