LS2 timing chain dampener
Old 11-16-2012, 06:14 PM
towerhand's Avatar
Default LS2 timing chain dampener
Does anyone have the part number for the gm timing chain dampener that will fit the 6.0 LS2 iron block. If not what year and model vehicle do i need to reference when calling gm to order. My local dealership cant seem to find what i am asking for. And also will this work with a double roller set?
Old 11-17-2012, 03:40 PM
3rdCoastPowerSports's Avatar
measure the distance from timing chain dampener bolt hole center to bolt hole center. That will eliminate alot of the guess work. Sorry i dont have a part number. If you give you the year make and model that the t chain dampener comes on i can give you the part number.
Quick Reply: LS2 timing chain dampener
