Ls1 engine removal
Old 11-17-2012, 09:31 AM
needtransam's Avatar
Default Ls1 engine removal
I've searched and came across some tutorials but im looking for a really good one with pics and everything, any options? Also found a video not sure how good is it
My plan is not to remove the engine but change the whole front since they're selling me the whole front en suspension for $200 and i just needed a rack replace but saw this offer and said why not,
Vehicle was crashed from front and i wanted to know what i should look for
Old 11-17-2012, 03:34 PM
3rdCoastPowerSports's Avatar
Not knocking you but engine R&R is a pretty strait forward procedure. You should be able to look at it and figure out how you want to Remove. If your not one of those people with a visual computer in your head (an engineer's mind) then you can try the SVC manual. Best how to out there.
Old 11-17-2012, 03:52 PM
Blu99T/A's Avatar
Can't help you at all as i pulled mine from the top. When I do it again, it will be from the top again.
Old 11-17-2012, 05:49 PM
wildcamaro's Avatar
Drop the whole k memeber assembly if replacing front end parts, but the motor can be pulled from the top if you do it right
Old 11-17-2012, 06:14 PM
wildcamaro's Avatar
Good post man I wish I had all the episodes of that LSgun project!
U don't have the next episode do you? Lol
Old 11-18-2012, 03:40 PM
oldmano2z's Avatar
when i first took my motor out i used that video and other info on this web site to smooth over the rough spots i found cause i'm not as tech savvy as the younger guys. any info that helps along the way makes things easier. " work smarter not harder" the oldman....
Old 11-18-2012, 04:35 PM
yeah doing it carefully don't want to mess anything up some people told me its easier than Im thinking, but Ill see what I can do will need help cause its not easy doing it by yourself. with the motor and trans out, Im guessing a heads/cam project will be pretty easy
Old 11-18-2012, 08:05 PM
sabersaw30's Avatar
https://ls1tech.com/forums/general-m...ls1-fbody.html
Old 11-18-2012, 08:25 PM
badazz81z28's Avatar
Wow, How Joe Elmore has aged....I like those old Horsepower shows. Know the location of more?
Old 11-18-2012, 08:50 PM
SWEET98SS's Avatar
I took mine out the bottom. I got it dropped in about 6 ours, taking my time. I have a two post lift which helped alot.
Old 11-19-2012, 12:15 AM
ldyzluvdis06's Avatar
this is what i followed the first time. took me a while because i kept looking at the post. second time (a few weeks later) it went much faster and much smoother. i could probably have it dropped in a few hours now without air tools.
and this it with me using a cherry picker to lift the car and jackstands. no lift. just take you time man, and raise/lower it VERY slowly in a silent garage to listen for anything getting caught up. and you dont need to remove the pcm or unhook it or anything so save a little time there.
Old 11-19-2012, 08:07 AM
CHADsterss's Avatar
Took me about 4 hours to reomove engine via dropping K-member, I had another person helping too.
Old 11-19-2012, 12:45 PM
mjs1012's Avatar
I dropped mine out the bottom and it wasn't bad at all. I watched that video a few times and looked at the engine removal thread a few times. Took maybe 6 hours doing it mainly by myself the first time.
Old 11-19-2012, 03:57 PM
gpr
gpr's Avatar
If the transmission is already removed is it that hard taking the engine out the top?
Way I see it is taking it out the top you still have to remove everything like you would the bottom, except you don't have to remove brake lines so you don't have to bleed brakes which to me is a big plus. Seems like i can never get the brake lines bleed as good as factory.
Also if you drop the entire k-member do you need to get an alignment again? seems like your alignment be off, as there has to be play in how the k member bolts up????
Old 11-19-2012, 05:19 PM
SnIpEz's Avatar
I know guys who can drop the engine from start to finish in 45 minutes, it's not too bad
Old 11-19-2012, 06:41 PM
Wow in 45 minutes dam lol
Question what can u use if you dont have a little cart to carry the engineor were can you buy one
Old 11-26-2012, 02:47 AM
AceBoogie's Avatar
drop it from the bottom. easier that way
Old 11-26-2012, 07:18 PM
td1168's Avatar
The link sabresaw30 gave you is an excellent one. Print it out in color and follow it step by step. If you have the means to lift the car pulling the engine from the top is foolish! I did the first f-body engine removal from the top. It is a pain in the ***! You don't even have to remove the radiator when you go from the bottom.
Old 11-27-2012, 06:51 AM
GMtechmatt's Avatar
i as well pulled mine from the top tore it down to shortblock and unbolted the converter and bellhousing and up and out
Quick Reply: Ls1 engine removal
